跳转到主内容
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
111 个问题 查看全部
Will it work with only 2 battery connections soldered on?
So basically while replacing the screen I broke the battery cable. I desoldered the flex cable and one of the solder points came off from the logic board. This is marked as 'TH', the + and - are still okay so I can solder onto them, so far I get a new battery will the iPod work with the battery only connected to 2 of the contacts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@itzdanbarker most likely not since the battery and the iPod are "communicating" with each other. The battery provides more than just power. The iPod queries it regarding charge status, prevent overheating and over charging etc. So you will have to try to rebuild the solder pad.
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
Daniel Barker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 105
