跳转到主内容
Released in 1989 by apple computer, discontinued in 1991
24 个问题 查看全部
I need help with my hissing monitor
i bummed the back of the monitor and now when i turn it on it hisses but still makes the chime noise and starts up the hard drive , i really need a fix asap cause i was fixing this up for my dads b day and now its broken please help anyone .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I agree with OldTurkey on bad caps. We used to buy complete repair kits with all the caps but those aren't available any more.
I had a 1984 128k M0001 machine sent to me last month, first with bad RAM and after that the caps failed after 5 hours. As I'm not up on this machine anymore I sent the power supply board to this guy and he did a great job on the repair with high quality parts, he is slow but does very good work, and his prices are very reasonable:
www.MacCaps.com
MACCAPS.COM 
22222 ROETHEL DRIVE
SUITE D
NOVI, MICHIGAN 48375
UNITED STATES
Charles Phillips
248 325 8812
这个答案有帮助吗?
得分 4
添加一条评论
jarrodebdon could be bad capacitors as well as an issues with the flyback transformer. Careful with that, lots of volts on the CRT part of the Mac. You'll have to open it up and isolate the sound a bit better. Take lots of pictures and post with your question. Use this guide for that. That way we can see what you see. Great place for schematics etc can be found right here. For your own safety, here is the Apple guide for that ESD-&-CRT-Safety.pdf Remember that all capacitors will still retain a current. discharge those before messing with it.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
jarrodebdon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 176
