跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Battery problem? (Percentage issue)
I have an iPhone 6 bought in 12/2014 and in March this year started to have some problems related to the percentage of the battery when it is near 20/25%, the phone turns off and says "no battery" but if I try to power on, fifth/sixth attempt later, boot with is 20/25% usually, sometimes the battery jumps from 25% to 10% and stuck on that until the battery really reach 10% when I connect the charger the percentage back to their normal, it all started when I upgraded my iPhone from iOS 9.0.2 to 9.2.1, I tried to clean install iOS 9.3.2 on iTunes but the problem continues ... this can be a problem in the battery or is a bug on iOS? I have less than 500 charge cycles.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
It shouldn't be that bad.. But then again Apple likes to do this kind of thing. I got my 6S on release date, and the charging port is already going bad. You could change your battery... I haven't heard anything about the new iOS hurting battery life..
iPhone 6 Battery
更换你的iPhone 6电池
iPhone 6 Battery图片
产品
iPhone 6 Battery
$29.99
这个答案有帮助吗?
得分 4
1条评论:
Battery life is not the problem, the problem is the phone turning off with 20/30%, i think i will try replace my battery, Thanks!
完成的
添加一条评论
found this blog http://www.etradesupply.com/blog/how-to-...
这个答案有帮助吗?
得分 1
1条评论:
Thought connecting to wifi would auto fix that...
完成的
添加一条评论
You can also try by using an original charger. Keep in mind that when you purchase an iPhone which is not brand new, the charger is not always an original one. So try to purchase an original iPhone charger and things would get better. If this helped you, follow me on IG @like_kyriee and i will follow back.
Regards,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Heitor Scatolin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,137
