跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
battery terminal on board water damaged
i tried ultrasonic cleaning to no avail, is there anywhere i can find to replace or resolder the battery terminal (the part the battery connects to on the mainboard) parts? The phone works only when its plugged in through charge, as soon as i take it out it shuts off, so from what I can say, I believe it's the terminal. Any suggestions on where to get the chip from?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
hi,you can resolder with a solder iron and rosin core solder ,magnifying glass helps.
这个答案有帮助吗?
得分 0
1条评论:
the battery terminal didnt come off its just got 'burnt out contacts'
完成的
添加一条评论
Hi, I have the same issue after water submersion. Switching batteries does not help. Did resoldering the battery terminal fix the issue?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,359
