跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 个问题 查看全部
Why won't my son's Nintendo DS read any games?
No matter what DS game we put in, it won't read the game. Nothing happens.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 51
21条评论
My ds won't let me press ok on it why is that
完成的
My ds does not read game
完成的
Hi I bought a memory card for my daughters Nintendo ds lite I cannot find where to slot it in. Any ideas
完成的
Pamela what kind of card did you buy (game, SD, etc.) and which model DS (Lite, 3DS, etc.)?
完成的
My DS doesn't make Enter tag and never return back while in an OK position.
http://appletechsupportnumber.net/ipad-s...
完成的
显示更多的16条评论
添加一条评论
11个答案
已选择的解决方案
When the unit starts, you will see the Health and Safety warning and "Touch the Screen to Start."
In the menu, where the DS game should appear, it is ghosted out and says, "There is No DS Card Inserted."
First off, to remove the possibility that it is not something extremely simple and overlooked, try this: http://www.nintendo.com/consumer/repair/...
It might just need to be cleaned. this is the simplest starting point, and needs the least amount of tech. http://www.fixya.com/support/r4080144-ds...
Past that, you can try replacing the Slot-1 slot on the motherboard, replace the motherboard, or get a brand new unit. I do emphasize the cleaning first. Being a portable unit, it's in pockets, backpacks, greasy hands, who knows what... You get the picture.
这个答案有帮助吗?
得分 13
10条评论:
+good answer
完成的
Maybe try getting a Nintendo 2DS *and yes, it can play 3DS and DS games*
完成的
9/10 it's dirty contacts that stops a game from being recognized. I usually start there with a q-tip and rubbing alcohol to clean those contacts. I also need to flatten the of the stick first in the q-tip to properly reach the contacts.
完成的
So does rubbing alcohol and a q-tip usually work should I try it
完成的
I got a blue nintendo ds lite for free because of this. They thought it didn't work. I solved it by putting a clothing tag in alongside the game. This is a solution that works for free. Try it before buying a replacement. Trust me. It may take a few tries but it works.
完成的
显示更多的5条评论
添加一条评论
最有帮助的答案
If you put it on auto, then turn it off and press the card in and out fast (about 10 times), then turn it back on, it should work. You also have to do the scraping thing.
这个答案有帮助吗?
得分 23
29条评论:
!!!My gosh!!!
I can't believe it !!!
It really works!!!!!!!!!
I didn't open it for few years!!!!
XDXD I'm so happy now!! Crazy
完成的
awesome!! worked for me also , thanks
完成的
Genius! Worked!!!
完成的
How did this work...
完成的
what you mean by auto
完成的
显示更多的24条评论
添加一条评论
my ds won't read a certain game but it will read other games
这个答案有帮助吗?
得分 1
3条评论:
Look into the card reader slot. If the pins in it are not bent take a fine emery board and clean them with short in/out strokes, move the board over and do it again - until you have cleaned them all. Do not move it side to side, you can bend the pins.
完成的
Try gently scraping across each contact on the game card with a knife blade, to clean off the contacts. If you carry the games around loose as I sometimes do the contacts can get dirty, and one or more may fail to make contact.
完成的
Bro this worked!!! Thank you
完成的
添加一条评论
This could be a nubeeee comment. My wife just got a ds light with around 15 games, separate case etc from the charity shop for £10. Turned it on. Inserted game and it didn't see the card. With no instructions. As we all do, turned to Google and found this thread. So cleaned contacts etc, etc. Still not seeing the cards. However, insert a card and then turn on and it sees and plays them fine.
这个答案有帮助吗?
得分 1
5条评论:
That is normal operation. Congratulations on your great deal.
完成的
My husband bought me ds too and we are having the same problem
完成的
@hush
@hhamy1234
Hi there, DS Lite units do not functions the same as the DSi/3DS and newer units. The DS Lite is unable to detect a game when the unit is on and a game is inserted. You'll need to turn the device off, insert DS Lite and/or GBA game into the DS Lite, then turn the system on.
If you want to change games, you'll need to turn the system off, change the game and turn it back on to have the DS Lite recognize the game.
完成的
Thank you!! My Ds lite wouldnt read any games. When I first tried this it didn't work. But I kept trying and by the 5th round of turning off the Ds and quickly pushing the game in and back out it worked!! Tyty!!
完成的
Excellent, worked with both of my ds's. Now we can play Mario kart. 10 mins ago nothing was working. Thanks
完成的
添加一条评论
my ds lite will read gameboy advanced games but it wont even read a ds game. It goes straight to the screen of pictochat and ds download play. it wont let me do anything else.
这个答案有帮助吗?
得分 1
2条评论:
@destinyr295 try taking a cotton swab (flattened a bit) with 90%+ of rubbing alcohol and clean the pins of the DS game slot. You've probably got dirty contacts.
完成的
What do u do when the cotton gets stuck in the game slot
完成的
添加一条评论
try putting a small stick like a needle behind the game make sure its in the middle it works because it pushes the game down and touches the pin or pins that are too small
这个答案有帮助吗?
得分 0
添加一条评论
If you've check your r4 cards is OK? Maybe your r4 cards is broken and you should get a new one.
http://www.r4i3dscards.com/
这个答案有帮助吗?
得分 0
添加一条评论
do NOT contact this spammer......
这个答案有帮助吗?
得分 0
1条评论:
why? whats wrong with it?
完成的
添加一条评论
dont do nm with "skruss" it is dangerous read ur information booklet
这个答案有帮助吗?
得分 0
添加一条评论
My Nintendo Ds lite Was not reading any game This is the solution I went to the DS turned it off and then I Just started to push the game in and out of slot 1 frequently about 20 to 30 times and then I turned on the screens turned white and it worked Oh I almost forgot you also have to put it in auto mode and wala therte you have it a working Nintendo Ds but the only down side is that you have to do this for every game you play but its worth at least it works though
这个答案有帮助吗?
得分 0
1条评论:
What do u mean by Auto mode how do u do that? Also, I only have 1 game Harry Potter Lego & it reads it fine, I can even play the game but when u turn the system on the screen has the Harry Potter link at the top then the basic purchase & Ds download to play. Under that is says there is no game pak to play, what does this mean? I can even click the download to play but it does nothing but search forever to no avail. I know it's not connected to my Wi-Fi and don't know how to go about doing that either? I'm wanting to ensure the system works to download play games so I can gift it to a friend's son as my neice received a Switch and no longer uses this but don't want the hassle if he has to buy game cartridges for every game he wants to play. Any help in what direction I should go. Tia
完成的
添加一条评论
Maybe Its Rusted The DS's Motherboard
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rasheen Barber 将永远感激不已
浏览统计数据:
过去 24 小时: 84
过去 7 天: 496
过去 30 天: 2,201
总计 458,874
