跳转到主内容
加入维修社区 - 创建账户
Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
Screen can't use it
My touch screen I can't do anything with it????it just gos nuts
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
4个答案
Hello Marvin
It sounds like your digitiser might be faulty.
You can buy a new one from here.
You can see a screen tear down from here.
Hope this helps.
David
My Computer Dude
这个答案有帮助吗?
得分 0
添加一条评论
Have you tried resetting your device? What about performing a firmware update? If problem still persists, open up the casing and check the ribbon cables. Make sure they are tight and snug (make sure your device is powered off while performing this step; will void your warranty). If the problem continues to occur, most likely your touch screen digitizer is faulty. It is relatively easy and inexpensive to replace (replacement panels start at around $8 on eBay or any other retailer). When buying a new panel, ensure that model and version number matches yours. Hopefully this helps.
这个答案有帮助吗?
得分 0
添加一条评论
  • Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. **)
这个答案有帮助吗?
得分 0
添加一条评论
My screen won’t work and I can’t get in
这个答案有帮助吗?
得分 0
1条评论:
And it’s cracked
完成的
添加一条评论
添加你的答案
Marvin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,064
