跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Loud Speaker not working after housing replacement
Ive replaced the housing on my phone right away the loud speaker was having problems when on low some sound will come out but when I put the volume up nothing come out at times when the battery is low and I attempt to hear something the phone completely loses power I've tried replacing the speaker and that did not work if anyone has a solution please share there are others with the same problem thank you in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
最有帮助的答案
Both the answers above are good ones, but make sure of two things that your dock connector assembly cable is in good shape, and that the connection to the logic board is sound. Having the speaker working and fine does you no good if your connection to it and the power source (the battery via the logic board connector) is bad. You may need to replace the dock connector assembly cable and when you do this you will have a chance to check out if the speaker is aligned correctly and is making contact with the connector. Get a good magnifying glass or a microscope to check the pins on the logic board connector and the pins on your dock connector cable. If they are bent, broken or crossed that might explain your loss of power issue. Sometimes small bits of metal dust can get lodged into the pins and case all kinds of issues. To solve some of these issues though you need to replace the whole dock connector assembly just to get things working again.
这个答案有帮助吗?
得分 1
添加一条评论
Are the dock connecter and the loud speaker alligned correctly?
这个答案有帮助吗?
得分 0
添加一条评论
Hi I had this problem to and it was resolved by slightly moving the loud speaker to the left or right. More so the left. There is a little room for play when re-installing the loud speaker. You also want to make sure the the cable is exactly where it should be.
这个答案有帮助吗?
得分 0
添加一条评论
I solved this by changing the entire charging port.
这个答案有帮助吗?
得分 0
添加一条评论
bro change your loud flex cable which is lubricated at housing panel
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Big bear 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,365
