跳转到主内容
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
221 个问题 查看全部
Replaced my Nexus 5 battery door and now my screen goes black
I replaced my Nexus 5 battery door/back cover because I upgraded to a Nexus 5X and wanted to get it ready to sell. I bought an OEM replacement on eBay and it matched the phone at both being D821 parts. Oddly though ever since I did that the screen started having issues with occasionally going off, glitching, or just going black even though the backlight is still on and the phone is still working (i.e. the notification light flashes, it vibrates, makes notification tones, etc.). Over time it got worse and the screen wouldn't come back on after hard rebooting. Literally every time I take the battery door off it has zero issues with the screen when I restart it. I find this extremely odd and I've closely inspected the battery door and nothing looks out of place as far as contacts or anything else that could cause some kind of "short" or something like that.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
This is strange... The only thing I can think of is the new door is making to much pressure and is disconnecting the screen cable... I would say look at the two doors and MAKE sure they are EXACTLY the same including length of things on the door...
这个答案有帮助吗?
得分 1
6条评论:
So funny you mention that. There's a little battery looking thing (I think magnet for wireless charging or mechanism for vibration) in the phone back. It came with a small black sticker on it that could be no thicker than a piece of paper. I removed the sticker and that helped for awhile and if I take the disc out completely it seems to help but then there's no haptic or vibration.
完成的
OK ya that little disc it the magnet for the vibrator (the wireless charging should be unaffected) try putting the disc back but inverting th polarity (as in make the North Pole face opposing to the way it was before) you may have to fiddle with it so... Also try flipping it over...
完成的
It can't be flipped because it's attached to a piece with two small spring contacts. Flipping it over would make those springs face the back of the case as opposed to the board where the contacts are.
完成的
I see...... Well the only thing I can think of it (if you want to risk it) you can try to take the same unit from the other door and st glue it to the new one...
完成的
P.S. There should be an orange ribbon cable over the battery is contains the video connections make sure that nothing is pulling on it and such, the connector for that cable is right below ware the disc things goes in...
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Phil Schroeder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 135
