跳转到主内容
加入维修社区 - 创建账户
PowerBook 1400 系列机型。于 1996 年 10 月发布。
PowerBook fails to power on at all?
A friend is trying to power on a old PowerBook 1400cs/133, but to no avail. I'm having a bit of a tough time trying to diagnose what could be wrong with it, as I've never operated on one of these PowerBooks before.
RAM, HDD, and battery all seem okay.
Is there anywhere specific I should be looking at (DC-in, connector?) to perhaps further diagnose this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Any corrosion or burns (short) evident on logic board? check cable/connector end to on button
完成的
My 1400 starts every time when I hit the small reset button on the back, the tiny button between the two inputs on the right.
完成的
添加一条评论
1个答案
已选择的解决方案
Try using a multimeter to test the output of the AC adapter. Ty resetting the power manager again with the battery removed and power adapter disconnected. Press/hold the reset button between the ADB and serial ports for 30 seconds, then connect just the power adapter and start up. Do you get anything, noise, or lights?
Reset the PMU, heres how: http://support.apple.com/kb/HT1781?viewl...
这个答案有帮助吗?
得分 3
2条评论:
I can't remember Richard--does this unit have a PRAM battery? +
完成的
Resetting the machine via the reset button isn't working. I suspect that the PRAM battery may be totally done for. I managed to order a new one, so when that comes, I'll have an excuse to crate a repair guide for this model for iFixit. :)
完成的
添加一条评论
添加你的答案
LambdaCalculus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 2,599
