DVD Burning technique guide?
I have a super combo drive. Can someone please guide me how could I copy tv serials files into a blank dvd (4.38 gb free space)?
Any software I have to download?
@ssvirani that will depend on how you download the files (which format) and which format you want to burn them. you will most likely need additional software i.e. "convert X to DVD" etc. More information is needed to completely assist you with this question.
这个答案有帮助吗?
So which format is compatible for burning movies into DVD's *as a media file not just as a data
Do you want to play those TV series on a DVD player? The you have to make sure that you convert it to the right format. Let me try and go through the steps. You will still need to let us know which format the files are that you download.
Download TV series file in .avi format
Open additional software (I use ConvertXto DVD4)
Go to ==>Action==>Convert==>Select your TV file==>convert
This will write and burn a DVD with the file on it. You can now use the DVD in any DVD player that supports burned disks
It is not very complicated once you know which software program you like. Like @benjamen50 said Nero is a good one and does a lot more. That is why I like ConvertXtoDVD since that is all that it does. Not a steep learning curve, straight forward.
Here is a good description on how to do with the software I am using.
I just download different tv series and I dont care about the format. All formats work on my PC. I just realized that /mkv format will not work on Windows Media Player
But Why should the movies to be download in .avi format? any particular reason?
And can you please provide me the link of the software that you use.
Use VLC Media Player. Supports a lot more formats than Windows Media Player.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 150
2条评论
Ah TV series. You need to make sure the device you are using supports that video format before burning the disc with a program such as Nero and other such burning software which ninite can install easily for you.
由 Ben 完成的
Can you provide me the link of most recent and sutained version od Nero, I googled it earlier but there are so many versions of it so I got confused.
Plus, I don;t know how to use it..
*I am curious why my ealier question (About Windows Installation) got deleted. You have any idea why this happened? Did I break any rules of this forum?
由 Salman Saleem Virani 完成的
