iPhone 5c time issue (time doesn't change)
Hey hopping someone can help, I recently got a iphone 5c that was dead, I replaced the battery and the screen and i got it working again. The problem is the time doesn't set automatically even though the setting is on and when I lock the screen the time stops counting.
Can anyone help?
UPDATE
Hey so I have noticed that the time changes when the battery is charging but stops as soon as the battery is 100%. Could this be a battery issue?
5条评论
Have you connected it to wifi?
由 iMedic 完成的
yes and I have tried to do it manually
由 Dmtech94 完成的
My dear friend you need to turn on locations then plug in with itune time will be reset automatically if not then restore your device time and date will be ok if you still getting same problem then put compass ic . thats it job done
由 Asad Abbas 完成的
Hey so I tried what you said still didn't work although now the time works but only if I have the phone connected to my pc
由 Dmtech94 完成的
my friend you need to change compass ic then micro soldring
由 Asad Abbas 完成的
