跳转到主内容
The M15x is Alienware's 15 inch extreme gaming laptop.
My laptop flashes but won't start
I get error code 0x030a191a reference memory at 0x00000000 the memory could not be read
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Check and reseat the RAM.
这个答案有帮助吗?
得分 0
添加一条评论
Unplug your computer and remove the battery. Then remove the 2 screws that hold the bottom cover on. Slide the cover forward and remove it. Next unplug the cmos battery, it looks like a black button about the size of a quarter. Press and hold the power button for 8 seconds, then wait an additional 5 minutes before plugging the cmos battery back in. Reassemble the computer then power it up. This should take care of the issue. Make sure if it does boot up normally after this procedure that you reset your date and time. Otherwise you will not be able to receive important updates or use your browser. Hope this helps...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 442
