person on the other end of the call can't hear me?
When I make a call I can hear the person on the other end but they cant hear me. What's wrong with my phone?
Hi,
Try using the earphones with the microphone attachment.
If the other people can now hear you OK and of course you can also still hear them, then there is a problem with the phone's microphone. Either it is faulty, has come loose of the systemboard or perhaps the opening at the bottom of the phone (small pinhole, behind which is the microphone), is blocked or covered over.
DO NOT stick a pin in the hole to see if it is blocked, you can damage the microphone. Use a magnifying glass to see if you can determine if there is something blocking the hole. If there is, try using a vacuum cleaner and see if it can be sucked out of the opening.
If the other people still can't hear you when using the external microphone then there is a problem with the phone's voice transmission circuitry and you will most probably have to get it professionally repaired..
这个答案有帮助吗?
where is the external microphone
Hi @ maryhelenaopray,
A lot of mobile phones have accessories consisting of earphones which have a microphone attached to it, so that you can use the phone without having to hold on to it. If you haven't got a set like this you may have to purchase them from any phone accessory store. They aren't very expensive.
Why can I hear the person but the person can't hear me what is the problem
Hi @lovenothate
Did you try what was suggested in the Chosen Solution above, you didn't say?
I tried all that I'm trying to microphone I tried to earpiece I was getting here a little crackling or some other hand
过去 24 小时: 4
过去 7 天: 27
过去 30 天: 148
总计 103,174
16条评论
ZTE phone I can hear them they can't hear me
由 Robin Everett-Price 完成的
Hi Robert Everett Price,
Did you try the solution as shown in the Chosen Solution below?
由 jayeff 完成的
What else could you do
由 Aniya jones 完成的
It's only one person
由 joey giacopelle 完成的
What are you trying to say here?
由 Cameron 完成的
显示更多的11条评论
