跳转到主内容
Released on May 1, 2015 by LG. Can also be identified by LS770.
26 个问题 查看全部
My lg g stylo power button doesn't work
My power button doesn't work on my lg g stylo. Does anyone know how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
9条评论
Did you ever solve this? I'm having the same issue.
完成的
I'm having the same problem
完成的
Lol if Albert Einstein can't fix it then nobody can XD
完成的
My power button on my stylo 4 isn't working
完成的
My button on the back of my phone don't work
完成的
显示更多的4条评论
添加一条评论
9个答案
最有帮助的答案
This worked for me.. take off the back case then plug in your charger. With the charger in remove the battery and put it back in. Restarted my phone. The power button is still not working but I can access it by tapping the screen. Hope this helps
这个答案有帮助吗?
得分 10
10条评论:
Thank you that worked. I had the same problem and I knew there must be a way to get it turned back on.
完成的
Thank you! This worked for me also!
完成的
WORKED!!! You're a genius! :)
完成的
this also worked for me
too !!
完成的
OMG I had the same prob,I have been trying to figure this out for weeks and it worked thank uuuu
完成的
显示更多的5条评论
添加一条评论
Taking off the back and taking out the battery for 15 seconds worked for me. I also noticed that the battery symbol showed it as charging, even off the charger, so that mustve been the glitch.
这个答案有帮助吗?
得分 1
添加一条评论
Try updating Android. That actually worked for me.
这个答案有帮助吗?
得分 1
1条评论:
omg this totally worked.. thank god!!!!!!
完成的
添加一条评论
Mine does that too… just keep plugging and unplugging the charger in a bunch of times and it eventually turns on.
这个答案有帮助吗?
得分 1
添加一条评论
I have to actually connect the charger and then in some cases kind of press the bottom of my phone to get it to vibrate and come on and then sometimes when I take the charger out it goes blank and I can't turn it on again but it does work with a charger plugged in
这个答案有帮助吗?
得分 1
添加一条评论
I was having the same issue earlier today. Tapped the power button repeatedly about 20 times out of frustration then held it down like usual the last time & it started working again. Must be a glitch or something. Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
I took the phone completely apart with a small screw driver and clean the contacts that lead to the power and volume buttons under the inside cover and put it back together and now it works fine.
这个答案有帮助吗?
得分 0
1条评论:
I could do this. Thanks!
完成的
添加一条评论
I went to setting in the display area and and turned off the switch for the power button and then turn it back on I haven't had problems since doing it
这个答案有帮助吗?
得分 0
添加一条评论
plug in the charger and press the volume down button holding down until it comes on if that did not work try it again still not working try different combinations with charger and volume buttons that worked for me but it took a few tries for sure. hope it works for you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tamikarose5 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 69
总计 17,401
