跳转到主内容
A smartphone by Nokia, successor to the Lumia 610, one of the first phones to run Windows Phone 8.
7 个问题 查看全部
问题已关闭
Digitizer is damage Lcd appearance is there
i have observed that digitizer has been damage though the LCD seems to be ok.
in such situation what need to be change?
please let me know what are the systems for bad digitizer and bad LCD
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
It depends how much you want to spend. You only need to replace the digitizer + glass. This will require careful separation between the glass and the LCD. If done improperly you can risk cracking / damaging the LCD. If you want to play it safe, you can get LCD + Digitizer + Frame for $20-$30 more.
You can get the part for just digitizer + glass + screen adhesive from here: http://www.ebay.com.au/itm/New-Nokia-Lum...
If the LCD does not display any more, then the LCD has gone bad too which means you will need to order at least the digitizer and the LCD.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 48
