Blue screen and not solve changing home cable
Hi
today i started to open my iPhone 5s to remove the battery and test it in another iPhone 5s, when i was opening, my home cable get out, without the gentile way.
After this, my phone started to show blue screen,
work for 1-2 minutes and blue screen, reboot, all again.
i tried to:
Reinstall iOS.
Change home button.
Change the main screen (with all camera, flat and button)
i DO NOT replaced the wrong screw on the wrong place and damaged the board.
i think it`s about home button, but, after change (for another one), it still having blue screen.
it can be the conector on the board/dock conector damaged?
Try unplugging the charging dock cable then try turning it on. If it still turns on fine then you need to replace the charging dock assembly.
由 Ben 完成的
Can i turn on without charging dock? i`ll try
由 freitasgabarrus 完成的
I tried to turn it on without charging dock, blue screen again...
what can i try more? battery?
I think this is board damage unfortunately. Probably a component chip shorted.
Apple logo then blue screen
This is what one of the users said, which is beyond my skill level:
- First change U2 IC and check if working
- Check backlight IC if same
- Then check and replace power ic if problem not solved
- Then most likely fault in processor or emmc now check these
由 Ben 完成的
i think its a board damage too =/ but its strange that he work for a while, sometimes 3min sometimes 30 min and blue screen and reboot, this made me hope that can be iOS, i will try downgrade version.
显示更多的1条评论
