跳转到主内容
A 7" tablet with a Android 4.2 (Jelly Bean) operating system.
30 个问题 查看全部
charged all night now will not turn on what's wrong?
Why won't my tablet come on or charge?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
BTW The microusb port does not work for charging. Need the OEM pin-plug adapter or a compatible pin-plug adapter 5V 1.5A (+) tip
完成的
添加一条评论
3个答案
最有帮助的答案
Maybe the battery has gone bad.
Do you have another tablet like that, which works?
If so then try taking the battery (if possible) out of the tablet that isn't coming on or charging and put the battery which is in the working tablet into the other tablet, if it works then you know the battery has gone bad. (make sense?)
However if you don't have any other tablets try replacing the battery.
Though the port thingy where you put the cable in to charge could of fried whilst it was charging..
这个答案有帮助吗?
得分 1
添加一条评论
It dont want to keep a charge and it cross on the main screem
Update (06/08/2016)
It dont want to hold a charge and cross on main scream
这个答案有帮助吗?
得分 0
添加一条评论
it is stuck on voyager lll screen and wont go to lock screen charges but wont go from there
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jeteshelton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 678
