跳转到主内容
发售于2014年春季 的一加 一拥有着5.5英寸的显示屏 运行着基于Android的CyanogenMod 12S操作系统。
110 个问题 查看全部
How to get rid of the colour seeping across my phone screen?
It used to be a small spot in the top left corner
I had a green and blue patch at the corner of my phone screen. The colour only shows when the screen is on (the brighter the screen the more visible the colour) and the abnormale colouring did not show up in any screenshots. It looks like water so I put it in rice for a few days. When I took it out it had only gotten worst. The colour has now seeped across the screen and limits visibility. What should I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
3条评论
Did the phone actually get wet before the issue started?
完成的
It may have gotten wet from humidity but it was never in water
完成的
yup. broken LCD as it is evidenced by the appearance on the right hand top corner. Replace it to repair your display.
完成的
添加一条评论
3个答案
最有帮助的答案
@angelblais without actually seeing your screen and only going by your description, it sounds like a broken LCD. You most likely will have to replace it. Here is the guide for that. Of course, to verify this you can post some images of what your screen looks like with your original question. For that use this guide
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
OnePlus One 显示模组图片
指南
一加 一 显示模组更换
难度:
中等
45 minutes
这个答案有帮助吗?
得分 4
添加一条评论
You may have dropped it recently and it didn't break on the outside bit leaked on the inside
这个答案有帮助吗?
得分 1
添加一条评论
I got only blue,black , violent shade on my phone corner
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Angel blais 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 56
过去 30 天: 241
总计 21,571
