iPhone 5 water damaged dead, it heats a bit while in charge
I have an iPhone 5 that is totally dead after water damage, I changed screen, battery, charging port... Everything, so the problem is the mobo. It only heats a bit while in charge and that's all. Suggestions? Thanks to all.
Did you clean the logic board with isopropyl alcohol? (Connectors, components, corrosion)
由 Ben 完成的
Yes, I forgot to mention. Thank you for your time
由 Mauro Campo 完成的
Mauro, we talked a little in that other thread. What percent of isopropyl alcohol did you use?
由 iMedic 完成的
99% I hope I used the right one
由 Mauro Campo 完成的
Yeah, that should be fine. Kinda surprised. The next thing to do is micro solder the u2iC chip. Do able. However, you do need some equipment
由 iMedic 完成的
显示更多的6条评论
