MBP Subwoofer Cone Rattled
Hello experts,
I'm using Macbook Pro 13" Mid 2010.
My problem is that the subwoofer broke, producing buzzing sound, the sound produce vibrate the whole body of my macbook on certain frequency.
I had open up my backplate of my macbook and checked, the subwoofer cone, the sort of leather like had peeled off which causing the sound produced buzz and vibrating the whole body.
It's an old model and I'm don't wish to replace a new subwoofer and don't mind the lack of surround sound.
I'm not an expert so my question is that if I simply remove the cone of the subwoofer, disconnect the wire connecting cone, will it damage or cut off the circuit of the right speaker??? Is it right to do so.
OR any experts please suggest how to disconnect the subwoofer from producing weird and vibrating buzz sound without disconnecting the right speaker. Anyhow I just don't want to replace the whole right speaker component.
Thanks and need help.
1条评论
On the other question, What happens if you remove the cone and disconnect the connecting wires ? -> Answer is : Nothing bad happens. I have done this i,e fully removed the cone in my 2 macbook pro (Mid 2012 and Early 2015 model) having the same rattling problem. Result is, NO rattling / no vibration, just sound is a bit lower than usual, specially the voice sound. Music is fine and sharp. I think I can live with this slightly lower sound. But overall I found no problem so far. Hope this helps somebody.
由 Ashiq Uz Zoha 完成的
