Why is my lcd still messed up?
I bought a fix it repair kit because the screen was shattered and would stop working randomly. Now that it is replaced the screen still wont work and still glitches.
Does the top of the screen have like a grey bar? If yes then the touch IC is most likely at fault and needs to be replaced.
More Information here:
这个答案有帮助吗?
yes. thank ypu
what could i do to fix it?
I would take it to someone that does replace touch IC replacements every day. It will cost quite a bit to repair and requires it to be professionally replaced. I'm afraid you can't do much to fix it.
Ella,
If you have done the repair yourself, though the house looks dirty.. if I was you, I'd grab a pipe cleaner and some Isopropyl. Dip the pipe cleaner inside and give a light rub across the terminals and make sure it's clean when you reseat the touch ribbon to the logic board. ;x
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 753
2条评论
Tel us more, what kit did you buy? what glitches are visible?
由 Job Wintjes 完成的
i bought the kit that included a new screen with all of the tools. the top of the screen with start to glitch and then the whole screen stops working unless i press down hard on one section of it. that is why the first screen shattered.
由 ellasimone2000 完成的
