跳转到主内容
戴尔所制造的笔记本电脑。
2273 个问题 查看全部
unable to sync Dell Inspiron 15 5000 model 5558 with itunes
I'm not the most tech savvy person out there so maybe I'm missing something obvious but I can't seem to be able to sync any of my apple devices to iTunes, I have check my checked my usb ports and cables and they're fine, I have the latest version of itune 12.3.3 and I tried connecting to iTunes with both an iPhone 4 with ios 7.1.2 and an iPhone 6s and nothing if I go to file and click on devices its completely grayed out I really don't know what to do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Is your computer connected to the internet?
完成的
添加一条评论
2个回答
I had the same issue a while back. Here's my little guide on how to fix it (If you are on Windows 7 or 8 it may look a little different). On your home screen click the Windows Icon on the bottom left corner
on the bottom there should be a search bar
type in drivers and click where my mouse is hovering
Then a program will open up and have a list
click on each of the bulletpoints and more options will come up
right click on the first one and this will appear
click "Update Driver Software" then this will pop up
then select "Search automatically for updated driver software" and then it will look online for new drivers and install them as shown here
just wait for a few seconds or minutes then repeat on each item there
这个答案有帮助吗?
得分 0
添加一条评论
Your cable might not be good. You should get an apple cable for your devices. using any other cable that isnt at least apple certified can reduce your total phone life and it might not work properly with your devices.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jose Miranda 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 280
