Phone won't turn ON or Charge.
Hey there Ifixit Community, i came to you because i think my phone done a short circuit, it was ON and pluged in an inactive USB port on my PC which i've plugged internaly just after.
Then i noticed that the low battery LED on the OnePlus doesn't blink anymore. First of all i thought about a complete discharge. But no charging LED. I've plugged the phone on the power adapter : No LED. This is when i started to freak out.
I've took appart the phone, removed the battery, mesured the voltage : 3.77 Volts. The battery is normaly 4.35 Volts.
Is it a big gap even if there is always a tolerance ?
Is my battery is dead ? Or something shorten the motherboard ?
I don't want to buy a new battery if this won't solve the issue, and i have no schematics to do a continious testing with my multimeter on the motherboard..
Any help is welcommed. Thanks.
Update (06/20/2016)
Is changing the battery will solve the charging, and the fact that my phone does not get detected by my PC ?
Update (06/27/2016)
If anyone got any ideas, like i don't know, a motherboard diagram or something that can help me fix this problem... Otherwise my last thing to do sill be to sell this phone for part and buy a new one. I've seen motherboard on ebay at 200$..
up please, i'm kinda lost right now...
由 Thomas Dangest 完成的
I have the same problem!
由 Luxas 完成的
My OnePlus 3T turned off and it wouldn't turn on again or charge. The trick that did it for me was to remove the sim card, turned it on, then put the sim card back. Hope it helps
由 Lalla 完成的
Keep your mobile for charging for 24 hr even it show no response then unplug and keep for atleast 12 hr test.then plug Charger to mobile ..may b at this it show low battery icon charging but if not then do this..:
1} Press power button for 30 SEC.
2}volume down button +power button for 20sec.
3) Still not show response then repeat whole process wih patience... Or u need to replace battery.
由 Vikrant 完成的
I had this problem (phone froze during normal use then powered off) and it turned on again as soon as I removed the sim card. This is the easiest thing to try first!
由 jamesolivermee1984 完成的
显示更多的8条评论
