跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 个问题 查看全部
问题已关闭
Won't power on, no charge light, tried multiple chargers, help!
Heya cool cats,
About a year ago I noticed that my old 2009 17" Unibody Macbook Pro stopped charging (magsafe light does not turn on) and then once it ran out of battery would not turn on or charge even when plugged in.
I tried three different Apple OEM Magsafe 85w chargers to no avail.
I've never replaced the battery since I've owned it, but it should still turn on when plugged in right?
I'm at a loss, what should I try next?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I would inspect the MagSafe connector on the system is the contacts clean and not deformed?
You may need to replace the MagSafe DC-In Board. Follow this IFIXIT guide: MacBook Pro 17" Unibody MagSafe DC-In Board Replacement
I would also check the battery checker to see if the LED's are lighting up at all.
MacBook Pro 17" Unibody (Early-Mid 2009) MagSafe DC-In Board图片
产品
$44.99
这个答案有帮助吗?
得分 2
添加一条评论
If you have another spare MacBook remove the I/O board and try it first before buying a new one. Just to make sure you know what you're buying.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 146
