跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
3379 个问题 查看全部
4 letters not working on keyboard
hi. i have an iphone with a board fault. when using the keyboard the letters (y,g,h,b)
dont work. i have tried a known good screen but the problem remains. am pretty sure its a board issue.
has anyon e come accross this problem before?
thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
1个回答
No, however something that comes to mind from past experiences and "may" relate to your problem is check the inside part of the phone/screen for any ripped conductor tape. there are so many interconnected grounding locations in these devices it is crazy. if you find a tear or tape missing from a place it once was, try some electrical tape to hold it over. Hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
trevor 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 379
