跳转到主内容
The Syma X5C is a four-channel quadcopter with a built-in camera.
30 个问题 查看全部
broken sprocket teeth repair
one of my motors has had two sprocket teeth break on the smaller sprocket on the underside of the motor. is there any way to repair that and if not is there a guide on how to replace that part?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi,
Here is a link to the Syma website X5C replacement parts page. You may be able to find exactly what you need here.
http://www.symatoystore.com/Syma-Spare-P...
Hopefully this is of some help.
这个答案有帮助吗?
得分 3
添加一条评论
There is an epoxy that's been around a long time and well respected due to it's abilities to permanently repair broken metals, after it hardens it's even machinable.
"J-B Weld" can most likely repair the gear for good. Comes down to how well can you shape/machine the sprocket to match the others.
It's available almost anywhere, auto shops for sure.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Infmaous xx89 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,631
