跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
When making calls, the other party can't hear me.
When I make a call through the handset, the other party can't hear me—but when I turn on speaker phone, they can hear me just fine. I can hear them, and the ringer works just fine.
Any thoughts?
Oh, and also, I can hear myself in the handset in an echo.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 79
32条评论
i have the same problem and seems to be the mic, because the sound recorder doesnt work either
it seems to be a hardware problem dude!!!
完成的
My friend has the same problem. We tried Skype Test and everything went fine. We recorded a show on tv via video recorder and it's fine so it means that the microphone is working fine. Viber is also working good. It's only when we are using the normal phone to call... The thing is that my voice is mirrored back as an echo but the other line cannot hear me. that is the problem
完成的
I have this problem for my phone too but I have an iPhone 5s. I can hear the other party but they can't hear me unless I talk on speaker phone. Has anyone had this problem with the iPhone 5s?
完成的
When making a phone call with my iPhone4, the other party can't heard me and neither that I, once I turn it on speaker it's ok. What should I do??
完成的
cristal there are lots of posts on ifixit regarding this problem. most likely it is the microphone on your dock connector which will need replacing. have a quick look at the "solutions" under the photo of the iphone 4 on this page...
完成的
显示更多的27条评论
添加一条评论
41个答案
已选择的解决方案
Hey Dustin!
I had the same issue a few months back. The cause was that it was stuck in headset mode. To see if this is the case, make a call, and turn up the volume. If it says headphones, it is stuck in that mode. You will need to clean out the headphone port with air. If this is not the case, here are some more troubleshooting
这个答案有帮助吗?
得分 28
5条评论:
Perfect solution
完成的
Fixed after one re-boot. The secret is push both buttons
完成的
Which "both" buttons?
完成的
My phone when my boyfriend calls me from jail it’s silent when I answer it it’s started yesterday morning an it’s only for his call how can I fix it
完成的
I have a iPhone 11 Pro max
完成的
添加一条评论
Don't hit your phone. Don't put anything other than an earphone in the jack. Definitely don't dissasemble the phone.
Press and hold both the home button and the power button until the phone resets with an apple. After about two minutes the phone will restart. You will need to do this two or three times. Each time your phone will react slightly differently. Don't be surprised after the first attempt if you loose both the mic and the speaker. Check the phone each time by having someone call you. THIS IS A SOFTWARE ISSUE.....NOT A HARDWARE ISSUE and the amatures on the web would have you believe. I admit rarely....rarely it may be hardware. 95% of the time this will fix the issue. This occurs on both I4's and I5's.
这个答案有帮助吗?
得分 25
31条评论:
It did the trick for me after I tried other suggested fixes, without results.
完成的
thank you. this did it for me on the first try. and special thanks for having me not visit an Apple Store 3 days before Christmas
完成的
Worked for me! Thank you!
完成的
I am so excited. Not sure what worked but something worked.
Thank you
完成的
I tried this technique 4 times but my phone still has the same problem.
完成的
显示更多的26条评论
添加一条评论
Clear the small hole near the headphone jack with a very thin pin. That should make it work.
Thanks Raj, worked for me with same issue. I really appreciate your help
这个答案有帮助吗?
得分 5
4条评论:
This solution works on my iphone 4, the one I call can hear me now. Thanks.
完成的
this solution worked on iphone 5c. I was going to pay to have it fixed!
thanks so much
完成的
yessssssssssssssssss.....my phone was not even iphone but this worked for my brand new Lenovo tab 2 A7-30HC with 3g supportive. I cleared the small hole near the headphone and hurraaaaaaaaaaaaaay it is working. Thanks for the support Jeff.
完成的
Good advice. Works.
完成的
添加一条评论
From what I've read sounds as though the microphone module on the dock connector and/or proximity connector needs to be replaced.
I've worked on several where I thought the proximity sensor was out, but, ended up being the mic module having trouble switching (and it is a cheaper and faster fix).
I've also came across a couple of jailbroken iphone 4's where the jailbreak caused the same issues (cydia).
For reference, here is a simple of mic locaitons, etc on the iphone 4:
(note #2 and #10, both are microphones, but have different functions)
http://ipod.about.com/od/introductiontot...
这个答案有帮助吗?
得分 5
1条评论:
I was facing same issue of voice not going out while calling. Thanks to above mentioned fixes. I did following and it worked
Resetting by holding Home and on/off buttons
Cleaning the small holes near jack with tooth pick
Thanks
Jamil
完成的
添加一条评论
这个答案有帮助吗?
得分 4
添加一条评论
u have to replace receiver
or u can connect your phone on auto loud speaker mode
steps :
setting>>general>>Accessibility>>Call Audio Routing>>Speaker
its best option if your receiver is not woking
这个答案有帮助吗?
得分 4
添加一条评论
I have the same problem, other party cannot hear my voice -intermittent - its annoying, I have to repeat myself many times. No lint in areas of concern. When I touch the phone or move in certain position then the party can hear. I purchased bluetooth aid but same problem??? cant hear me.
这个答案有帮助吗?
得分 2
1条评论:
Try starting a new question.. This one is old an only looked at for reference. You'll get more help that way
完成的
添加一条评论
Check to make sure there is no pocket lint in the headphone jack. Lint, dirt, and other debris can send mixed signals to the phone causing similar issues. I like to use the pro picks that I purchase from ifixit for this task and a can of air if needed.
Also, the iPhone 4 in many cases is still under warranty - it's something to always check out on newer devices.
这个答案有帮助吗?
得分 1
1条评论:
I have same problem in redmi note 4 what I will do now reply fast
完成的
添加一条评论
My problem is the caller can not hear me on speaker, everything else is just fine, when I use the phone on an app that you talk into it works just fine, what could be the problem.
这个答案有帮助吗?
得分 1
添加一条评论
I scoured the Internet for a fix, and I've found a few hints that narrowed my problem down.
SYMPTOMS (With Microphone, Ear Buds, or Bluetooth):
I call and callers can't hear me.
In/Out calls work for a few seconds, then callers can't hear me all of a sudden.
All other applications that use the iPhone microphone work, yet phone app on does not.
HINTS FROM INTERNET:
Loose back glass screws.
Put pressuse on left or right bottom corners of iPhone 4.
POSSIBLE FIXES:
While testing (facing the back glass), I made calls and put pressure on the left and right sides of the bottom of the iPhone 4. Sure enough, not one could hear me unless I pressed the right bottom of the ihone 4. Once I let go, they can't hear me again. Putting pressure back on, they can hear me.
FIX (So Far):
I unscrewed the bottom two screws and removed the back glass. I pre-cut a piece of manila folder about one square inch, and layed it inside the back bottom right, and put the back glass back on. My theory is that the piece of manila folder put just enough pressure on the internal components so that I did not have to manually do it.
IT WORKED!!!!
DISCLAIMER: This is just my fix. I, nor this forum, take any resposibility for damages to your iPhone if you attempt this process.
这个答案有帮助吗?
得分 1
添加一条评论
iPhone 4 the caller can't hear me, but i can hear them fix
try here worked for me
https://www.youtube.com/watch?v=s21dOrOn...
这个答案有帮助吗?
得分 1
添加一条评论
I had the exact same issue looked down all avenues reset etc.
Finally changed lightening port and the mic problem was cured.
Worth a try!
这个答案有帮助吗?
得分 1
添加一条评论
just to make sure, try to use voice recorder, if u can record ur voice properly, means no prob with the microphone... and probably the problem is with software or the proxim sensor...
这个答案有帮助吗?
得分 0
添加一条评论
I had this intermittent issue where callers could either not hear me or hear static. I did a complete reload of the software and reset the network settings on the phone but the problem always came back. I finally got to the point where the problem occurred all the time so I decided to open it up. I removed the battery and the speaker/mic assembly to check for debris but I found nothing. I also could not find any liquid damage on the board. I reassembled the device and now the phone works great. The only thing I believe it could've been was that the screws may have loosened and the board was not grounded. I've seen this happen to laptops just from typical transport or movement. Just something to consider if you see this problem however if your phone is still under warranty, have Apple service it.
这个答案有帮助吗?
得分 0
添加一条评论
Using earbuds fixed my problem. Well, at least, it's the only way they other party can hear them. without out earbuds i can hear them perfectly fine but i'm inaudible.
这个答案有帮助吗?
得分 0
1条评论:
Try a new dock connector to replace your microphone.
完成的
添加一条评论
I could hear them fine, but they couldn't hear me unless I was on speaker or bluetooth. It was an intermittent problem, but then more persistent.
I tightened the tiny screws at the bottom of the iphone4, as suggested above, and hooray! It is working again!
Thank you Michael Romero and Jason :)
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem after a downthrow. I heard the others but they did not heard me on a normal phone call. Free speech via Bluetooth did also not work. Then I had found these Youtube Video and -> it works fine :-) I only need even two pieces of paperboard on top of each other.
这个答案有帮助吗?
得分 0
添加一条评论
loosen the tiny screw at the bottom part of the camera, paper didnt work for me, my opinion here is just an opinion any harm that can happen to your phone was not my fault, or if you want you can go ahead and watch the video on youtube.
这个答案有帮助吗?
得分 0
添加一条评论
My problem is solved. I had the same problem described here but it was solved by removing just one recording app I had installed and did not know it is causing this echo problme for a few weeks. To exclude all the problems regarding your downloaded apps you should back up your phone and without restoring reset your iphone to a new iphone. Again do not do a restore. Then try calling someone. You problem might have been resolved.
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem and used a can of air duster to spray the earphone jack and charging dock. Problem solved! : )
这个答案有帮助吗?
得分 0
添加一条评论
pssfotr
这个答案有帮助吗?
得分 0
添加一条评论
We cleaned it, played with it, and eventually it was replaced by Sprint. This was not my phone. Man, I forgot I had posted this. Thank you for all the help you guys are great.
这个答案有帮助吗?
得分 0
添加一条评论
When you use bluetooth to phone calls can be heard coming from different countries will be able to listen to the calls viber have the microphone? Gusto telecom brand
这个答案有帮助吗?
得分 0
添加一条评论
I can hear people & music without speaker on but they can't hear me until I put them on speaker
Update (10/28/2015)
Why can I hear others I call through my ear piece and also not speaker yet they can't hear me unless I put them on speaker ?
这个答案有帮助吗?
得分 0
添加一条评论
I also had this problem but it's that if I put myself on speaker then they can't hear me any answers?
这个答案有帮助吗?
得分 0
1条评论:
I also had this problem but it's when I put my self on speaker please give me some answers.!!❤️
完成的
添加一条评论
I hear but the person i call cannot hear me even i used headset or not
这个答案有帮助吗?
得分 0
添加一条评论
the correct fix would be changing out the dock connector which has the speaker in it,cheers supafixa
这个答案有帮助吗?
得分 0
添加一条评论
worked first time for me.....thank you so much
这个答案有帮助吗?
得分 0
添加一条评论
when i have my phone on speaker my voice cuts out, i also hear my voice at times on & off the speaker...can you please fix these problems?
这个答案有帮助吗?
得分 0
添加一条评论
The callers claim they cannot hear me when I turn on speaker.
Please help!
这个答案有帮助吗?
得分 0
添加一条评论
People can not hear me but I can hear them
这个答案有帮助吗?
得分 0
添加一条评论
Simple answer.
https://www.youtube.com/watch?v=Khon7Uhj...
这个答案有帮助吗?
得分 0
添加一条评论
When I talk the other person can't hear me , but I can hear the person , in the other side I can receive calls from whatsapp good
这个答案有帮助吗?
得分 0
添加一条评论
I have tried EVERYTHING. I have an iphone 4 and haven't been able to hear people talking unless I put them on speaker phone; this has been going on for 3 months. That means I have to have a lot of NON-private phone calls when I'm out and about and a call comes in. The elaborate and ridiculous recommendations most of these well-intended, advice givers hand out over the Internet about fixing this issue; doesn't work. Yet, this simple one did!! I did exactly as Dustin said to do and the phone worked, fine, as soon as it powered back up. I will flag/tag this site so that if my phone calls are ever "muted" again, I'll know exactly what to do! Now... Dustin, can you help me figure out why my blow dryer stopped working last week? LOL
这个答案有帮助吗?
得分 0
添加一条评论
Sometimes when I'm talking to someone on the phone all of a sudden they can hear me why is that
这个答案有帮助吗?
得分 0
添加一条评论
When l making call, ghe other party cannot hear my voice
这个答案有帮助吗?
得分 0
添加一条评论
People cant hear me on my iPhone 7 plus but i can hear them .? What can I do to fix my phone
这个答案有帮助吗?
得分 0
1条评论:
People hear can't hear me but I can hear them
完成的
添加一条评论
ohhhhh myy godd it workeddd ... ...... a single pin solved myy such a big problm nd saved me going to apple store nd spend a big amount on it... huraahhh thnkuy soomuchhh !!!!!
这个答案有帮助吗?
得分 0
添加一条评论
Same problem, Samsung Galaxy 5, I can hear them fine, they can't hear me. What's really odd is that people CAN hear me fine on video chat, just not regular phone or messenger non video chat. Took my phone in to Sprint, and ended up getting a new phone anyway (obviously long overdue, got the LG V30+ for $12 a month for 18 month lease on special ((reg $38 per month lease)), plus $13 per mo for the optional insurance). But still wondering whats up with my Samsung.
这个答案有帮助吗?
得分 0
添加一条评论
I find the best fix is to place the IPhone into the dishwasher then microwave for three minutes,take out fry in hot oil then tape it to car bumoer and drive off a small 14 foot cliff into a river. When you get to the ocean,check phone again.
这个答案有帮助吗?
得分 0
添加一条评论
I have a lot of work in WhatsApp, but I get annoyed from many conversations. Is it possible to hide the appearance and the message receipt mark, as in WhatsApp Omar, and if it is not available, is it possible to install WhatsApp GB. It doesn't matter, I want to install any version other than green.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dustin 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 40
过去 30 天: 152
总计 649,791
