跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Searching for network problem
hi every one
i have problem with my iPhone 6 i jest format it from settings
and after that the phone could't find a network ( searching )
i set the time on phone automatically and reset network settings
but it didn't work.
help me please
thank you
and sorry for my English
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
@oscarpants Dial *#06# and tell me if the IMEI is displayed when doing so. If not, you have a Baseband IC issue and would be a hardware repair reballing the IC with Microsoldering and running a couple jumpers to pads under IC.
这个答案有帮助吗?
得分 1
添加一条评论
Have you tried a restore through DFU mode?
Open iTunes and connect the iPhone to your Mac.
Press and hold the Home button and the Sleep/Wake button at the same time.
After exactly 10 seconds release the Sleep/Wake button.
Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
After that just click restore.
这个答案有帮助吗?
得分 0
添加一条评论
hi
I just got iPhone 6 and it keeps on searching I keep on restarting it but still keep searching I don't know whts wrong with it. please help me kim thanks
这个答案有帮助吗?
得分 0
添加一条评论
Try to perform a restore from recovery mode. https://support.apple.com/en-us/HT201263, this will put a fresh copy of the iOS on you device.
Note make a backup of your iPhone first.
When you set up it choose "set up as new and test."
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ali alhashimi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 360
