跳转到主内容
修复你的物品
维修的权力
配件 & 工具
The PSP 3000 was released in the U.S. on the 15th of October 2008.
76 个问题 查看全部
My psp3000 cannot charge via AC power
Since I tried to user old car charger to charge my psp3000 and it didn't work, I cannot charge psp3000 via AC power anymore.
I've already try to use the adapter with another psp and it's ok.
How do I know that my psp motherboard was short curcuit or just the female plug or damage.
And if the motherboard was short curcuit, can I repair it by myself.
Thanks a lot for your awnsering !!!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Did you repair it ? I have the same problem
完成的
添加一条评论
任天堂 Switch 套装
A quick fix to get back in the game
Shop Switch Kits
任天堂 Switch 套装
Shop Switch Kits
4个回答
已选择的解决方案
How old is your battery? always look for the easy stuff first :) and than make sure that the battery makes good contact. If I remember right the PSP has fuses on the MB. It has 2 fuses (LD) One marked TB. The other is located beside the power cable disconnect.So by using your car charger you may just have set off one of these. Of course to fix it you will have to open it up and get to them. If you are under warranty with your PSP, don't do it. Go to Sony and replace it. Otherwise, you don't have anything to lose, try to fix it and let us know how it is going. Good luck
http://www.yall.net/Forum/Repair-Center/... and http://www.youtube.com/watch?v=h-TEeWRvl... might help you.
这个答案有帮助吗?
得分 1
评论:
Just realized how old this was :) like I said I am really confused. Hope this is still relevant if not...Oh well :)
完成的
添加一条评论
Hi,
The charging connector is connected to the motherboard by 2x wires cable and small white connector. Near to this connector you can find one fuse (charging fuse). Check it and replace it if necessary. This is most often charging problem.
Regards.
这个答案有帮助吗?
得分 1
添加一条评论
I think you might be better than buying new. The price is not expensive. Can not be charted charted with a car. But chart with other charts it 's allright. Your psp would not be damage. A charted in car broke.http://www.excellenttoday.com/
这个答案有帮助吗?
得分 0
评论:
okay I am now really confused :)
完成的
添加一条评论
Is it mean fuse can find from any place…?? Bro you frist know why psp not tearn on not do any thing damaged your psp…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thanasarut Sasismit 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 12
过去的30天: 56
总计 8,818
