跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1505 个问题 查看全部
Why won't my iPhone turn on unless it's plugged in?
Hi there,
I purchased a used iphone but it won't turn on unless it is plugged in to the wall (it won't turn on if plugged in to the computer, and thus, itunes won't recognize it).
When plugged in to the wall, it shows the apple logo, and then immediately goes to the 'connect to itunes' screen. However, when you unplug to connect to itunes, the screen goes black and it won't turn on.
What do I do? Would a battery replacement help?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
评论:
I seem to have found myself with this problem, my phone was running iow4.3 and I jb so I thought it was that, I did a factory restore and it did t work, I can only use the phone if it's plugged it.
I haven't put it in rice because I don't think it's gotten wet
Should I just replace the battery ?
That's what I would do. It sounds like your battery and it gives you a solid starting point. This way you know that your battery is not part of the problem and it makes it easy for any further troubleshooting, if that should be necessary.
yep, this battery if original is probably at the end of it's life.. 3years old?
I have the same issue and it is the result of water damage. Did yours get wet at all? I was able to fix my issue by leaving it plugged in for about 14 hours. Miraculously fixed it. After replacing the battery though I am not getting the same issue.
Hey Nick, thanks for your response. I'm not sure about the water damage (the seller says no, but I bought used and it looks like the iphone had previously been opened and tampered with). I tried leaving it plugged in for over 14 hours - no success. Based on your suggestion, I've ordered a new battery so we'll see if that works. Any other suggestions are welcome!
显示更多的3条评论
添加一条评论
5个回答
已选择的解决方案
Hey there. I have repaired many iphone's with this exact same problem. First I try a new battery (most of the time that fixes the issue). If the battery does not work, than try a new USB doc port. Sometimes you have to replace both. Also make sure that the two gold battery contacts on the logic board are cleaned off. If still no luck, than you probably have a bad board.
Good luck.
-Nick c
这个答案有帮助吗?
按维修分数 0
评论:
Hi Nick, whilst it's fab you gave advice, we aren't allowed to advertise our own companies etc. You're welcome to put a link on your profile page. I've deleted your link from here. Cheers
Good eye Polly.
添加一条评论
最有帮助的答案
Hi. I had this exact same problem after replacing a cracked screen. The first couple hours it turned on just fine, but would randomly shut off, and the same the next morning. So I took the phone apart to make sure all connectors were cleaned with alcohol and firmly in place and that none of the screws were loose.
But now It would power on and work perfectly only when plugged into a wall, but would immediately shut off when unplugged and would do nothing when plugged into the computer. What was even more frustrating is that the phone did show the battery, it's % (almost full), and showed charging.
One last try, I opened up the back and took out the battery, as I unscrewed the tiny grounding piece near the vibrator, I wasn't sure if I had it the right way. I checked the pictures in the guide it looked like it might be upside down, so I flipped it, put the battery back in and presto, my iPhone worked again, WOOHOO!
Funny how it can be something so simple sometimes.
I've spent hours looking for an answer to a problem and have it be where I can't even find the subject, let alone a solution. So hopefully this will be helpful to someone.
这个答案有帮助吗?
按维修分数 1
添加一条评论
I had this problem iphone 3GS would only turn on if plugged into mains. The button on top does not work so used on screen button to lock but then couldnt switch back on. I seem to have got around this by turning off the auto lock timer to never. I then switch on with mains and then unplug. The screen eventually turns itself off but I am still able to press home button to switch on again. Strange but true!
这个答案有帮助吗?
按维修分数 0
添加一条评论
My phone had starting exhibiting the same behavior after dropping it I eventually found that applying pressure to the bottom right of the phone resolved the problem. I tried applying a binder clip over the area and the phone started working as expected. It seems like there is some kind of contact not being made with the battery and the pressure is perhaps closing that gap. In the end this provided me a working phone until I can get a replacement.
Thanks,
Mike
这个答案有帮助吗?
按维修分数 0
添加一条评论
Don't get a cheap battery they have usually cycled 200 times plus. Pay the silly money for an original Apple battery.
Update
Whooo just remembered Don't forget to clean the end on the grounding pin. Oils on your fingers will effect it :-)
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
james 将永远感激不已
浏览统计数据:
过去的24小时: 12
过去的7天: 53
过去的30天: 331
总计 54,873
