跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
224 个问题 查看全部
won't vibrate
My phone has stopped vibrating all together, caused by a drop possibly. I have read that if you smack it on the back corner it will work again . . . not for me. Is it the vibration motor that has gone out? If so, what part do i need in order to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Here is the part you need, you need to replace the whole headphone jacks, which includes the vibrator. There you will find links to the step-by-step installation guide and everything else you need.
这个答案有帮助吗?
得分 0
2条评论:
Thank you!
Does it matter which part number i get?
完成的
I don't believe so
完成的
添加一条评论
添加你的答案
Pat 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,547
