跳转到主内容
A Nokia E-series smartphone with a physical QWERTY keyboard and Optical Navi Key. Successor to the E71. Released in 2009.
11 个问题 查看全部
USB charging not working
WHen I connect using micro USB cable to the charger, its not getting charged. I can only charge the phone using the charging port at the bottom. Also when connecting phone to the USB its not even detecting. How can I fix or repair that.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi Sandeep,
Try this:
Remove the battery in order to avoid short circuits during procedure.
Take a needle and pick out all dust and dirt that is in the USB socket of your device. Quite a bit will be there.
After cleaning, reinstall the battery.
I hope this will help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sandeepthomas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 15
总计 1,107
