跳转到主内容
The TI-84 Plus Silver Edition is a graphing calculator released in 2004. It includes a USB port, pre-loaded software, APPS, storage, and a removable front and back case.
32 个问题 查看全部
Why doesn't my calculator turn on?
My calculator doesn't turn on even when I put in new batteries. Is it the calculator's battery problem (the one that is in the calculator). How do I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
it is possible your caculator is not wired correctly
这个答案有帮助吗?
得分 0
2条评论:
What do you mean by not being wired correctly? My calculator was working when it suddenly stopped turning on.
完成的
you could've pressed a button to many times and it messed up the wiring inside
完成的
添加一条评论
添加你的答案
Sophy Kim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 248
