跳转到主内容
索尼的新一代电视游戏机,于2013年2月20日发布,并于2013年11月15日开售。
1695 个问题 查看全部
PS4 Controller Issues since 3.5 update
After the 3.5 update my controller would work correctly.
I have managed to work out that i think it has to do with the bluetooth?
The controllers work perfectly when connected to ps4 via usb cable and when within 1m of the unit (cable might not do a thing, might just be that its close)
any further than 1m and it goes haywire and usually just turns itself off like its out of range.
Is this a coincidence or the 3.5 update. done it with 2 brand new controllers as well so its def the console side.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
I removed the wifi antenna and re attached, not sure how this is related to the bluetooth at all.
i also moved the ps4 to hip height on the cabinet, turned it around so the back faces my direction and played for an hr or so with no issues.
完成的
Are they wireless controllers? Did you check the batteries?
完成的
they are built in batteries, they are fully charged as they work within 1m
完成的
添加一条评论
4个答案
已选择的解决方案
Hi! Usually this type of problem is caused by a bad WiFi antenna. I haven't heard of this happening because of the update but that's always possible.
Here is the WiFi antenna repair guide if it helps.
Good luck!
这个答案有帮助吗?
得分 1
4条评论:
I took it apart and removed the wifi antenna, it looks fine, all solder joins are in tact and no damage anywhere else. it was connected properly to the main board. It's down to the update or a faulty motherboard. Just a coincidence that it happened straight after the update was installed.
完成的
Wow, that's surprising...well it's possible that the update caused this but I just haven't seen this problem from the update.
完成的
I can't think of anything else that could cause it besides the ps4 going faulty at that exact time the update was installed.
its working at the moment now. i put the ps4 on top of the cabinet instead on in it and turn it around so the back is facing my direction and now its working. im guessing a faulty bluetooth adapter or software issue.
完成的
It could be either of those.
完成的
添加一条评论
Still no luck fixing this. Bluetooth range issue for sure. Is there extenders?
这个答案有帮助吗?
得分 0
添加一条评论
i work on a service store to video games in dr and we have the same trouble some many times we fix a few reinstalling the full update but have another s still bad and we make it a reballing on the blue tooth and others fixes but has anothe few than never wnat to work again sorry 4 my bad english im latino and dont know much how to write
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue, but only when I have the external 8TB HD extended storage connected to the PS4 and playing a game on the System HD. It all stopped after I disconnected the external. So I doubt there's Bluetooth or WIFI connectivity issue. Some bug in the update may be causing it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris Dowling 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 8,556
