跳转到主内容
Samsung WB2200F 60x zoom dual grip camera released in 2014.
6 个问题 查看全部
How do I prevent my adapter from overheating?
I am trying to figure out what can be done to prevent the adapter from over heating.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I was in this problem before
But i stooped use adapter
no i use SD card only
and everything right
完成的
添加一条评论
1个答案
I had this sort of problem in the Philippines for a TV adapter. Due to the extreme heat of the country and the lack of airflow the ac adapter was overheating and the TV would turn off after a certain amount of time. So I had on of those Gel Cooling Pads for a laptop which I was not using. Mine looked like this.
http://www.amazon.com/Heat-Absorbing-Lap...
Anyway I wrapped it around the power adapter brick and rubber-banded it on.
OF course you might use something else but remember you are dealing with power so be careful.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rachelle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 473
