跳转到主内容
修复你的物品
维修的权力
商店
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
949 个问题 查看全部
Housing replacement.Screw is not coming out :/
Hi guys.I need suggestion.I was about to replace housing for IPhone 6s Plus because it got scratch so bad.Everything went well but until I got to the screw that holds flex cable and motherboard on the upper left side.I think I stripped that screw and I don't know how to take it off.Should I get different types of little screwdrivers and try to take it off or can I do anything else?Maybe that because I use those chines srewdrivers that comes with housing replacement :/
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个回答
最有帮助的答案
Hi @danhorski stripping screws happens to everyone I have done countless times I know it's quite frustrating but I got a solution for you 如何卸下滑丝的螺丝。 removing stripped screws are not fun but this guide has really helped me out and the methods work. I highly recommend you give the solutions a try. Your screwdrivers are good because if you stripped a screw that means they are hard tipped and are stronger than the screw and that's what you want. but if your screwdrivers don't grip the screw well then I would try a different screwdriver maybe a wiha or an Ifixit pentalobe screwdriver set. The bit kits are great to and make sure the Screwdriver head fit's tightly into the the screw to prevent stripping the screw. I hope this helps.
这个答案有帮助吗?
得分 1
评论:
It did not helped.Srews is so little.Only once option use retory tool :( but I'm scared because there is no way to it without damage.
完成的
I just thought up a good solution use a diamond needle file like these http://www.olsonsaw.net/shop/zona-hand-t... I would go back and forth with the tip of the flat file or the edge of it and it may take a bit to get a slot in screw but you will have a lot of control with these and if that doesn't work maybe @tronicsfix has an idea because I am running out of them.
完成的
添加一条评论
添加你的答案
Daniiel Tsykhorskyi 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 194
