跳转到主内容
Budget tablet with 7.00-inch 1280x800 display powered by 1.3GHz processor alongside 1GB RAM and 5-megapixel rear camera.
28 个问题 查看全部
"Data Wipe failed" on Lenovo 3500
Lenovo tablet Stopped working. after trying to rest or factory rest it normally goes to android reboot and factory rest page .
but after selecting "Wipe data/factory rest''" error is:
Data Wipe Failed !
the error repeated in all of the season !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
4条评论
it solved - tnx
完成的
Hi @h1773073 ,
Care to share the answer for anybody else who comes across this problem? ;-)
完成的
How to solve this problem?
完成的
How to solve this problem ?
完成的
添加一条评论
4个答案
最有帮助的答案
Have you tried doing a factory reset using the Volume Up and Down and Power keys? If it freezes you can use the reset button in the SD card area.
See if this helps: Lenovo A7-40, A7-50 A3500 Factory Reset
这个答案有帮助吗?
得分 2
2条评论:
This button does not work
完成的
If the button does not work then you might need a replacement for your device the PCB or new device in general (although I would always choose repair over replace). I would look at the guide I posted and see to replace the board. You can find the part from various third party's, just use the right model of the device or open yours for the part number if you can't find it in the manual.
完成的
添加一条评论
i have the same probleme help us please
这个答案有帮助吗?
得分 1
添加一条评论
точно такая же проблема! кто-то смог решить?
这个答案有帮助吗?
得分 1
添加一条评论
wipe failed I need solver this problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
1773073 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,112
