跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
202 个问题 查看全部
doesn't boot up only shows charging
After screen was replaced on my HTC M8 the phone will not boot up it only shows charge and amber light but it doesn't actually charge.. The charging port was replaced just in case and I also did the charging logic reset but nothing has worked..any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
So you get charging light but no display on the LCD display correct? For me it ended up being a faulty LCD.
完成的
Well the answer was I didn't push down on the battery connection I only screwed it in ..
完成的
添加一条评论
1个答案
已选择的解决方案
Well my fix was that when I installed the new LCD in the RE install I DID NOT push down on the battery contact I only screwed the connection so oven if I did a logic reset or changed the charge dock it would never boot. So I took it apart and the phone booted up. Problem solved .. took me a week but we win...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 115
