iPad 2 in a boot loop after a battery disconnect and reconnect
I replaced the back cover on iPad 2 and exchange all components to new cover including some being replaced new. When finished I power up to test all functions. I got a good boot and home screen but in less than 2 minutes in went into a boot loop with about 1 minute delay after boot before home screen appears then 1-2 minutes and boot loop and won't stop. Any suggestions?
2条评论
Have you tried charging it for like an hour or more while turned off if possible?
由 Ben 完成的
I was able to fix it, what I did was go back and remove the logic board disconnecting the battery clean the battery contacts with alcohol allowed to air dry and reassemble. it worked perfectly no more problems
由 Danny Hartley 完成的
