跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Water Damage - Error -1? Can't Restore
Hi,
Dropped my iPhone 6 in water and it turns on fine, but goes to the "Connect to iTunes" screen.
When restoring it in DFU mode or normal mode, It comes back as error -1
If i'm correct this is a baseband issue yes? Do I need to replace the baseband modem ic chip? And if I do can I use any off the internet or do I need to replace it off an existing iphone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You cant replace the baseband without using factory tools to rewrite the device serial number, so this is mostly a lost cause.
这个答案有帮助吗?
得分 2
添加一条评论
Use the iFixit part. It does sound like a baseband issue. The one from iFixit is going to work, or they'll give you your money back. It's a quality part, and I don't trust much else...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brick50 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 112
