跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 is constantly searching
After a visit to the apple store my iPhone 6 as been deemed damaged I wiped out with phone in back pocket, the back-plate took a bad hit and the iPhone 6 now as a bend to it causing a slack between the screen and back-plate (bottom only and snug at top). It has been fine ever since but recently decided that It would start "searching" Apple tech says this could cause antenna (he says attached to back-plate) to loose contact with sim card causing the phone to search or short(fried) the sim card. Not sure if that is possible. So we replace sim card, it worked for a 2 weeks it started doing the same thing, drop signal and search. So I started holding the phone and apply pressure at the sim card location (thumb on screen & index on backplate) during power cycle and to my suprise, the phone would lock signal work for a while then suddenly drop and search. Sadly this trick no longer work and the phone only work under WI-FI. i have tried holding at the bottom, top and middle without success.
What parts would you suggest I replace or perhaps check first before buying new parts.
I'm looking to replace only the bent back-plate but do I need more? antenna and such?. I'm confident in my skills to take apart my phone and rebuild with know good parts.
Is the antenna attached to back-plate? or am I wasting my time.
https://onedrive.live.com/redir?resid=D7...https://onedrive.live.com/redir?resid=D7...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Try going settings > general > about. Do you see an option listed for iccid?
Iccid is your SIM card. If it's not there more than likely the phone can't see the sim so its be something to do with sim reader as opposed to antennas.
这个答案有帮助吗?
得分 1
2条评论:
How'd you get on with this?
完成的
So if ICCID is shown but no service the antenna is the issue?
Can Apple replace that? How much does it cost?
完成的
添加一条评论
Hey Nigel, thanks for answering, I did all kinds of research and elimination process to pinpoint the problem.
The very first step was to replace the rear panel, It was bent(one ding at battery connector area on logic board also, see pics ) out of shape enough to not ignore. After the replacement that went very well, phone looked new, on startup the phone found signal without any issues. It only lasted a few days. then back to searching... as per your ICCID suggestion, I tried to simply remove the card and power the phone, go to "about" and see if detected...it did.
I'm thinking the Logic board might have gotten hurt enough to intermittently (weld or connection of some sort) fail.
这个答案有帮助吗?
得分 0
1条评论:
It looks to be super common, just a problem that happens.
I've seen some people reheat some chips to get it working again.
I dind't go down that path.
完成的
添加一条评论
It seems to be a logicboard issue. Time for a new phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Laurent Legrand 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 959
