lost signal after a second.
I have a problem I can not figure out how to solve. When I turn on the smartphone takes the signal for 1 second and then appear the notification "restricted access changed" and the signal is not working more , I tried to set only 2g , 3g only , but nothing seems to work. I tried to make updates and wipe but nothing , how can I understand the problem ?
Hi, Have you tried your SIM card in another phone to see if it works? Have you tried another known working SIM card in your phone to see if it works?
由 jayeff 完成的
I tried to enter my sim in other phones and it works and I quote sim of other operators . With my brother sim is 3 ita but the signal comes TIM ita and the signal does not disappear but if I try to call out I wrote " not available cellular network . "
由 Giacomo 完成的
Is your phone locked to a different network? Maybe that is why your bother's SIM does not work in your phone but it does show the networks.
It may be that your SIM card has a problem with your phone only. It is not unknown, different thickness card different pressure on the SIM card reader contacts etc. Try to get a replacement SIM card for your phone and see how it goes..
由 jayeff 完成的
ok now do I replace the sim with a new one, the two wind ita are cut instead of that of my brother 3 ita is original micro-sim.
由 Giacomo 完成的
I changed the sim with a new but no change , that of my girlfriend has the same operator wind IT and setting 3g and 2g works. But if I change the network settings even with his sim I have to reboot to get back the signal. currently I use OxygenOS 2.1.4.
由 Giacomo 完成的
