跳转到主内容
Released in September 2014, the Samsung NX1 is a smart camera that utilizes the unconventional mirrorless lens system.
11 个问题 查看全部
Why won't the battery door on my camera stay closed?
When I try to shut the battery hatch door, it won't stay closed and in place. Why does it keep opening?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
The battery may not match the Samsung NX1 camera. Read the battery label to make sure you have the appropriate battery type.
这个答案有帮助吗?
得分 1
添加一条评论
The battery may be inserted incorrectly. The battery does not need to be forced into place. The blue tab should slide into a groove that holds the battery in place on the negative-positive side of the battery. You must also push the battery all the way down, so that the spring is compressed, and the blue tab locks the battery into place.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hannah Patrick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 972
