跳转到主内容
The Panasonic LUMIX DMC-LX100 is a compact digital camera with 12.8 MP resolution, 4K HD video capabilities, and Wi-Fi access. It was released in November 2014.
23 个问题 查看全部
filter is set to 'none' and everything is blue.
the filter is set to 'none', yet everything looks blue. in order to take pictures without the blue effect, I now actually have to select a filter like 'expressive' or 'high key'. how can I fix that?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Check your White Balance. This is a setting that adapts the color rendering of the camera to the ambient light. For example, if you'd take pictures indoor under "warm white" artificial lighting the pics would all look yellow if your white balance were set for daylight. Vice versa, if you have your white balance set for indoor lighting and take pictures in outdoors daylight or with flash, the pics will come out with a blue tinge.
To set the camera's white balance, press the WB button and use the control dial to select the type of white balance according to the ambient light, then press the MENU/SET button. For more detailed info, see p.44 of the camera's basic user manual.
If you don't want to be bothered with have to set the white balance manually each time the lighting changes, set it to AWB (Automatic White Balance). This way, the camera itself guesses the type of lighting for each picture, and this usually works well.
这个答案有帮助吗?
得分 10
2条评论:
Thank you! I wish I had found your solution before I went on vacation. All of my burst and panorama shots have a blue hue. Next time I'll be set. THANKS!!
完成的
My filter effect button has stopped working on Lumix DMC-LX100. How do I fix this, please?
完成的
添加一条评论
添加你的答案
birte 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 93
总计 7,925
