How to power Apple TV 4 in the car? 12v adapter?
Is there a 12v power supply solution for the Apple TV 4? I want to be able to run the apple tv from the 12v ignition supply from the car battery so that i can run videos to the car screen.
You'll need a car DC to AC converter like this one: Tripp Lite PV150 Ultra 150 Watt Power Inverter so you can plug in the AC cord of the AppleTV into. We use these for our field staff to use their laptops in the field.
There is no 12volt power supply option for the AppleTV it was never designed to be a mobile device.
这个答案有帮助吗?
Yes I already have one of those adapters but I want something more neater hence asking for a 12v solution. I know someone has done it on the apple tv3 but wondering if a newer one has been released
http://carsystems.com.ua/universal-solut...
I just ordered this to install an Apple TV 4 in my camper. Did not receive it yet.
这个答案有帮助吗?
Did you receive it yet?
Yes, I received it. It took quite a long time to travel, although it was posted next day. This seems to be due to customs. Nevertheless it arrived and is a really good solution. Even the 220V connector is replaced for a standard low voltage connector. It works like it should :-)
I philippemeyers did you order it from the Ukraine as I've sent them a skype to find out where i can get one
Did you hear back? Where did you order from?
I ordered one from http://carsystems.com.ua/universal-solut...
works perfect and the service was very good
Is the way to do it without spending a nickel
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 29
过去 30 天: 64
总计 35,758
5条评论
How do you expect to stream from iTunes?
由 Dan 完成的
I don't need iTunes, my car has a built in wifi hotspot and I can tether from my phone or iPad for Internet. The new Apple TV has apps so it's more than just an iTunes Player
由 Deleted193439577 完成的
From my understanding AppleTV apps are still tethered to iTunes for them to run. So you'll still need access to the internet as you are driving.
由 Dan 完成的
Yes as I have said I have wifi hotspot built in... Now how about you try and answer the actual question Dan ?
problem solved
http://www.askuncledave.com/2017/08/appl...
由 David Ferrandino 完成的
