跳转到主内容
Model A1625. 2015 revision to Apple's set-top-box featuring an A8 processor and 2 GB of RAM.
30 个问题 查看全部
How to power Apple TV 4 in the car? 12v adapter?
Is there a 12v power supply solution for the Apple TV 4? I want to be able to run the apple tv from the 12v ignition supply from the car battery so that i can run videos to the car screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
How do you expect to stream from iTunes?
完成的
I don't need iTunes, my car has a built in wifi hotspot and I can tether from my phone or iPad for Internet. The new Apple TV has apps so it's more than just an iTunes Player
完成的
From my understanding AppleTV apps are still tethered to iTunes for them to run. So you'll still need access to the internet as you are driving.
完成的
Yes as I have said I have wifi hotspot built in... Now how about you try and answer the actual question Dan ?
完成的
添加一条评论
5个答案
已选择的解决方案
You'll need a car DC to AC converter like this one: Tripp Lite PV150 Ultra 150 Watt Power Inverter so you can plug in the AC cord of the AppleTV into. We use these for our field staff to use their laptops in the field.
There is no 12volt power supply option for the AppleTV it was never designed to be a mobile device.
这个答案有帮助吗?
得分 1
1条评论:
Yes I already have one of those adapters but I want something more neater hence asking for a 12v solution. I know someone has done it on the apple tv3 but wondering if a newer one has been released
完成的
添加一条评论
http://carsystems.com.ua/universal-solut...
I just ordered this to install an Apple TV 4 in my camper. Did not receive it yet.
这个答案有帮助吗?
得分 1
9条评论:
Did you receive it yet?
完成的
Yes, I received it. It took quite a long time to travel, although it was posted next day. This seems to be due to customs. Nevertheless it arrived and is a really good solution. Even the 220V connector is replaced for a standard low voltage connector. It works like it should :-)
完成的
I philippemeyers did you order it from the Ukraine as I've sent them a skype to find out where i can get one
完成的
Did you hear back? Where did you order from?
完成的
I ordered one from http://carsystems.com.ua/universal-solut...
works perfect and the service was very good
完成的
显示更多的4条评论
添加一条评论
Here is a US seller of the Apple TV4 PS: http://www.ebay.com/itm/122333123212
这个答案有帮助吗?
得分 0
添加一条评论
Here is another:
http://mct-corp.com/store/index.php?prod...
这个答案有帮助吗?
得分 0
添加一条评论
Is the way to do it without spending a nickel
https://m.youtube.com/watch?v=cao5UahhN6...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Deleted193439577 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 47
过去 30 天: 122
总计 34,776
