跳转到主内容
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 个问题 查看全部
Starts one kick but revs really high.
I have a 1982 suzuki fa50 it starts right up but wants to take off the throttle cable isn't stuck and I cleaned the carb. What can cause this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I'll try it tomorrow morning. Let you know thanks
完成的
添加一条评论
3个答案
已选择的解决方案
The carb usually has a set screw on the side of the throttle body that governs the throttle opening for the engine to run idle. Look at the carb from the left side of the bike, there are two screws. The one on the right (closest to the air intake) should be turned all the way in - gently! - and then one and three quarters of a turn out. The one on the left (closest to the cylinder intake) is the idle adjustment. Officially it should be set so that the engine will idle at 1500 rpm. If you don't have a rev counter, set it so the engine idles smoothly with a reasonable safety margin before it engages the clutch.
这个答案有帮助吗?
得分 5
2条评论:
@flyingdutchman hope you do not mind me adding an image of the carb to your great answer.
完成的
@oldturkey03 thanx, you're welcome!
完成的
添加一条评论
U may have you idle screw turned in to far,or u r running too lean
这个答案有帮助吗?
得分 0
添加一条评论
Air leak somewhere!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dominick caswell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 7,568
