跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
问题已关闭
Why can I only hear a call over speakerphone?
I replaced the integrated LCD and Display assembly on a working but iPhone with a cracked LCD and display. Now when I make or receive a call, the only way I can hear the other party is if I put them on speakerphone.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
9个答案
最有帮助的答案
I had the same problem and I fixed it. I just opened the iphone because my wifi no longer works. When I closed it up well the place were you hear the calls did not work anymore. Well the trick is to make sure your connector 3 is well put back in place. It is the orange flabby one behind the number 2. Before you pop the 2 back into place you need to put the 3 in. Lift the white tab on the logic board. It might be already lifted and then insert the 3 into it. Like putting a piece of stick gum inside your mouth. Then close the white switch back down and it should lock the 3 into place. Then proceed with the 2 and then 1. This will surely fix the issue.
这个答案有帮助吗?
得分 1
添加一条评论
this is my exact problme. i hope someone has the answer for us. ive taken these thigns apart many times, never this problem.
这个答案有帮助吗?
得分 0
添加一条评论
Was this resolved? I have the same problem.
这个答案有帮助吗?
得分 0
1条评论:
Check cable3. No change then either replace cable or speaker and cable. Check eBay. Speaker usually comes as part of midframe
完成的
添加一条评论
I replaced the cracked screens of mine and my daughters 3gs iphone. My daughters phone worked perfectly once the job was done. All functions on my own hone also worked perfectly. However when i made or received a call the otherparty heard me ok but I could only hear them if i used speaker phone function or my headphones.
I read this post and re-opened my phone and low and behold the ribbon inside labelled 3 had come loose!!. What a great find . My iphone 3 now fuctions just as it should I can hear calls as normal. i was at a loss before I found this post. Thank you.
So if you have replaced your screen and can only hear your calls through the headset or speaker phone and all other sounds are ok , re open your phone and re fix the 3 connector it will have come loose !! hooray Good luck Donna
这个答案有帮助吗?
得分 0
添加一条评论
andrecharbonnh20 hit the nail on the head. Thank you, his advice fixed mine.
这个答案有帮助吗?
得分 0
添加一条评论
I replaced my screen then could barely hear my calls. Check your tone volume. Make a call and then push the volume button (same button you use to raise the ringer volume). Making a call allows this button to control the hearing level.
这个答案有帮助吗?
得分 0
添加一条评论
the proximity sensor in the phone display is bad or not connected in the socket all the way. try pushing it in to the socket up to white line. if that does not work replace proximity sensor. good luck.
这个答案有帮助吗?
得分 0
添加一条评论
Way do u mean u re opened ur iPhone???? I'm having the same problem
这个答案有帮助吗?
得分 0
添加一条评论
Opened the phone is when I unsecrewed the bottom screws and used the suction cup to lift the display out of the socket.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 14,004
