跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
505 个问题 查看全部
Why are my tires locked up?
I have a craftsman yt 3000, 21 hp mower and have this problem. It will not roll, the tires seem to be locked up so I jacked it up and the tires spin freely, one in one direction the other in the other direction. Any idea what I've got going on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
It's very likely that it's related to the transmission or the drive belt, not the tires.
Here's some more info:
http://www.mytractorforum.com/14-craftsm...
  • Check the clutch/brake travel. Are you sure you don't have the parking brake set when you are checking belt tension?
  • Do you have the little finger thingy sticking out of the rear plate that allows you to push by hand. Is that out or in?
  • It's possible that the pivot for the tensioner has rusted up, if it's been sitting. Getting under and eyeballing it should tell you.
这个答案有帮助吗?
得分 1
评论:
the drive belt looks to be in place, why would the tires spin in opposite directions?
完成的
Because differential gear boxes : https://www.youtube.com/watch?v=SOgoejxz... which are universally present on vehicles that have more than one drive wheel.
完成的
添加一条评论
添加你的答案
jimm 将永远感激不已
浏览统计数据:
过去的24小时: 12
过去的7天: 67
过去的30天: 308
总计 17,429
