跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 个问题 查看全部
How do I fix a broken audio-out jack?
I accidentally knocked a line that was plugged into my audio-out jack. Now, nothing works in that jack unless I fiddle with it for a very long time, and sometimes it never works.
My Mac speakers work, but I can't plug anything into the audio-out jack to use large speakers.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Sounds like you broke the tip off inside the receptacle. If so you can open it up and slightly pull out the center bracket of the back of the port and remove the tip.
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
Hi there, if the suggestions that you've already received doesn't work then just simply replace that I/O board for your machine, I don't think that they cost that much.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
slicesofamerica 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,918
